All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have a master space heater model 150 paraffin, runs ok with the cover off but when i put the cover back on it stops. The flame out button clicks to shut the heater down. any info please
Anonymous
Level 3:
  • All-Pro Master 43,501 Answers
  • Posted on Jan 16, 2011
Anonymous
All-Pro Master
Level 3:
Answers
43501
Questions
0
Helped
10838187
Points
101584
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
2answers
Runs with cover off but reset switch kicks off when cover is installed
It may be over heating check vent ports verify no obstructions reduicing air flow.
Paraffin heater fault E1
Which model is yours:-- Here is a link to their web page-- does this help?- - Mack B.
http://paraffin-heaters.blogspot.com/p/portable-paraffin-heaters.html
Which model is like yours? Mack B.
Sylvania electric stove heater, black (model SO111R-MBK) stopped working
Got a stove electric space heater But it will not trunk on just the flame button but no flames and no heat what can I do to fix this .boxes the remote control have to light up....Albert Gomez..2124 North Keeler ave..Chicago Illinois..60639...18722062470.....
Where is the flue/flame sensor located at on my Pentair master temp 400gas heater?
Hy my pulsar 150 slow running bymitake off I try start not start continue kiks after 10 to 20 munitus I again start plies my problem sove
1helpful
2answers
These units have a air pump on the back of the fan motor. Has anyone messed with the settings? The pump usually runs off of 5 to 6 lbs. of pump pressure. This is what controls the fuel flow that is sprayed out of the fuel injector. This unit also should have a photo eye for flame out control. It is positioned near the ignitor looking though a hole in the combustion chamber. Make sure it is clean and looking in the hole. Make sure your ignitor is working also.
Space runs 15 seconds then stop
check in front of the flame there should be a flame proving rod which may be dirty, use steel wool to clean it so it can sense the flame, could also be a "fire eye" like a light sensor for a outdoor night light, clean the lense
2helpful
Motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Heater runs for 20 minutes then shuts off
These heaters have built in thermostats. Sometimes they are adjustable sometimes they are not, check to see if your is adjustable and see if this fixes your problem. Also check to see if there is any air restrictions possibly causing the heater to over heat.
Top All-Pro Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
