The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the
breaker for at least 5 minutes if this does not correct the problem you
will need to replace timer/electronic control.
This may be a stuck button issue. Press all buttons several times each and you may have luck unsticking the button. If not the keypad will have to be replaced.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
