Question about Amana ABB1927DE Bottom Freezer Refrigerator
Bottom freezer coils freezing up
Coils behind panel in the freezer section are freezing over with a thick coat of frost which causes the refrigerator section to get warm.  what needs to be done to resolve this problem?
  • 2 more comments
  • Anonymous Jun 30, 2008
    refridgeratro not cooling freezer works fine
  • lynnj Jul 06, 2008
    Freezer coils get thick coating of ice and refrigerator gets warm. We defrost the freezer and the fridge will work again. this solution only last at the most about 1 month and we are back where we started. Lately the time between defrostings is getting closer together. I have seen this problem posted by others. the only solution offered is to defrost but this seems like there is a mechanical failure of some kind. Should be a more long lasting solution!
  • Anonymous Aug 16, 2008
    bottom freezer icing over
  • Anonymous Mar 17, 2014
    freezer coil ice up and freezer gets frost and too cold and bottom of refrigerator too warm
DEFROST PROBLEM CHECK YOUR DEFRST HEATER,DEFROST T-STAT=LOCATED BEHIND THE PANEL BOTH ARE LOCATED ON THE COIL WITH A OHMETER OR DEFROST WITH HAIR DRYER IT WILL HELP FOR 10 DAYS OR SO.
Posted on Jun 25, 2008
6ya staff
SOURCE:
Defrosting Problem
HI,
Did you try unpluging all the cords from back for 3 hours and then plug it back in.This is know as a hard reset.
Jun 13, 2008 | GE Monogram ZICS360NRRH C... Bottom...
My fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
Dec 01, 2012 | Refrigerators
Frost build up on back panel. 3 weeks ago used hair dryer to melt ice behind panel that was on the coils. Now we are getting frost on the coils and the top of the freezer door. Refrigerator section is now...
The defrost cycle on this fridge is not working. Ice is building up, restricting the air flow to the food section causing the area to warm up, the defrost components need to be tested to find the fault
Apr 01, 2011 | Whirlpool Refrigerators
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
22 cf kenmore side by side not very cold. Large ice block formed behind backplate on upper coils. thick frost on lower coils and on inside back of freezer section. Still making ice and fan blowing,...
also perhaps the defrost timer is bad, not allowing the defrost heater to come on and melt the ice as it should? Or the defrost heater itself could be bad -
Oct 07, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
MY GE refrigerator is freezing in the freezer section and the refrigerator. However, this is only at the bottom to slightly below the half way Mark. Thisis a two door refrigerator freezer. One half is...
Do not know how to find a repair in your area, but here is what is wrong:
The cooling coils, located behind the back wall of the freezer section, have frosted up, preventing the normal flow of air. Now, some of the cold air in the freezer is sinking and flowing into the bottom of the fresh foods section through the air vent by the bottom bin. To fix this, disconnect power to the refrigerator and unload the freezer side. Remove the panel at the back of the freezer section and melt all the frost and ice. Replace the heater at the bottom of the cooling coils, which would normally take care of the frost build up. Reassemble and restore power.
Nov 12, 2009 | GENJRS06 Electric Single Oven
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer is defrosting
Many times, on a fridge with automatic defrosting, there is a sensor at the back of the freezer section (behind the plastic) that detects a freeze condition - sometimes these go bad, In normal operation, usually once a day, the timer sends a signal through this sensor and if it shows a frozen condition, it activate a heater (yes, a heater) in the freezer section that melts and defrost the coils. If this system stops working, the ice builds up and closes up the air passages to the fridge section, causing it to warm up, while the freezer section ices up!
Check for icing and maybe try defrosting a little by removing power for a little while. Move any food to another fridge while you are fixing it. The freeze sensors are easy to change, but be careful - electricity can kill. Always hire a professional if you have any doubts about your ability to perform the work yourself.
Aug 30, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
227 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
