The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
maybe you should clear up your memory card and release disk space. and if the camera still have the nosie,maybe there is something wrong with your lens. the lens maybe too loose or too tight.it has something to do with the lens mount. www.skiliwah.cn/ http://www.digitalcamera-parts.net/
MSN:[email protected]
e-mail:[email protected]
cindy
Set you Message Storage Destination to Memory card and delete unwanted Smses or Bluetooth received files from the phone memory. To do this, Go to message settings and there's an option with "Default destination" or something like that, and set the Storage to Memory Card.
You'll also need to close the programs that are running on the background. To do this press and hold the "Menu" key, and to close the particular program, press "C".
Good luck
Thanks for using FixYa.
It's possible the camera won't take an sdhc card. Or maybe you just need to move the slide switch on the side of the card to unlocked or that you need to format the card in the camera.
Take your memory card out and move the tiny plastic switch on it to "unlock" or whatever it says. If that doesn't help, try another card. If that still doesn't help, come back and we'll try something else!
ive been trying for ages to do this and its so easy but no one seems to be explaining it easy! Your phone without the memory card only holds one or two songs. you must have songs in there for it to say memory full. Go to this song press options , file, move to extrenal. Now try and send a song through bluetooth. You will be able to recieve it now you have freed up spave on the phones own memory. Remember to save it to external straight away so u can recieve the next item. Easy peasy!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Remove the camera batteries Put the card back in the photo printer and take all your pics off ,then reformat it and put it back in the camera with the Batteries .
I suspect that you did not format the card with the camera before you started using it. The card MUST be formated by the camera before anything is put on the card.
you can solve this by inserting the card into a card reader and using the computer to delete all files and folders on the card. Then put the card into the camera and format the card with the camera. do not use the computer to format the card.
i hope this will help.
