SOURCE: Pixelated blacks and face shadows
take it back to where you purchased it and get it exchanged.
SOURCE: hooked up cable box, wii box and dvd player to new
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
SOURCE: I have an LG47le5400 tv and a LG blu ray player
I have the same problem! Viewing regular t.v. is fine, as is any VHS tape. But when playing DVD or Blu-Ray, I get dropouts. I've tried three different players and two different HDMI cables. So it must be the HDMI receiver within the actual LG t.v. Would love to know how to fix this without having to replace the television.
SOURCE: I have a 32" flatscreen
Different video signals use different connections
...and we are speaking ONLY the video(NOT including the audio connections)
These are the common analog video signals....You cannot mix and match these and plug a composite (Sometimes called AV in menus) into component etc
If both your sources (wii/DVD) you want to use a component signal to your TV (which BTW is the best quality of the 3 I listed) you will need 2 component inputs on your TV
OR
run it through a high end receiver (that will act as your switcher)
OR
buy a small stand alone switcher, something like:
http://www.amazon.com/4X1-HD-Component-Av-Selector/dp/B000BVIBGI/ref=pd_sim_sbs_e_4
settle for a lower quality DVD signal and use the Composite video out (yellow jack) into the Composite Video In on the TV and use the component for wii
I hope this helps,
Magoo
