SOURCE: door locks problem with one door drivers door
dont blame the idiot,we all make stupid mistakes without thinking and iam no exception,remove door trim and oil the solonoid with a oil can not a silly sunday mechanic spray and let it soak in as its working but i think its just a bit sticky with wear and dirt ingress hence it locks but doesnt unlock which might need a bit more power,oil the whole lot lock and all
SOURCE: Can not open any door using the key or remote control.
Hmm, probably a dead battery. The problem with those locks is that they are electrically actuated, not mechanically unlocked. Thats why the key turns easily. If you turn and hold it to the unlock position, and the battery is okay, the windows will roll down. If they dont, then its the batt. Call a mechanic.
SOURCE: 2005 honda accord doors will not open with remote
need an actuator for the driver door need more info go to collisionrepairadvice.com for how to do it yourself
SOURCE: Drivers Door Lock Problem
You will probably need to replace the power door lock actuator.
Here's a link to one similar to yours.
http://autorepair.about.com/library/a/1g/bl467g.htm
You can probably get a used one from a salvage yard.
Try this site to find one near you:
http://car-part.com
If you need more help post a comment.
Tim
SOURCE: transit doors not locking
james i have had the same problem on a transit an trace the problem in the wiring to the rear right door where the wirin goes through the plastic slider between the door and the vehcle i had to cut out the damaged wiring and run new and solder up make sure the wires you put in are long enough too so you can open the door all the way , failing this think logically which is the door opened and closed the most ,ther might be your prob in the wiring between the door and vehcle
