Question about Kenmore Elite 45986 Front Load Washer
Does kenmore recommend liquid or powdered detergent for front load machine
    New Friend:
  • 33 Answers
You can use liquid or powder.
Use only High Efficiency detergents. The package for this type of
detergent will be marked "HE" or "High Efficiency." This wash
system, along with less water, will create too much sudsing with a
regular non-HE detergent. Using regular detergent will likely result
in washer errors, longer cycle times and, reduced rinsing
performance. It may also result in component failures and
noticeable mold or mildew.
Please vote
Thank you
Posted on Nov 28, 2010
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Only HE detergents should be used in these washers. High-efficiency front or top-loading washers are designed for low water level and a tumbling washing action. HE detergents are low sudsing and specially formulated to provide clean washloads in these energy-saving washers.
Use of any other kind of detergent in a high efficiency washer, not only can confuse your washer cycle but prevent it from washing or rinsing properly. HE detergents are comparable in price to other detergents; look for the symbol and ensure you are using the correct detergent for your high-efficiency washer.
    President:
  • 2,702 Answers
Liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
2 Suggested Answers
Anonymous
SOURCE:
duby1990
Justin Duby
  • 370 Answers
SOURCE: Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Posted on Feb 20, 2009
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Where do i put liquid detergent in top stacking may tag older model
Just pour the liquid/powder into the wash tub prior to loading clothes... this machine does not have a detergent dispenser...
Jul 06, 2014 | Maytag Neptune MAH5500B Front Load Washer
Why can't I use liquid color-safe bleach in Kenmore Elite top loading washer?
IF the instructions advise against using bleach in that machine then it is probably because the bleach will affect certain parts / rubbers of the machine and will lead to costly repairs if used.. Try a bleach free soil remover like nappy-san or vanish pink in conjunction with a liquid detergent rather than a powder detergent
Aug 03, 2013 | Kenmore Elite 45986 Front Load Washer
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
I have an ariston awd 121 front loader washer dryer. What kind of soap does it call for? Can it be the powder? Does it have to be liquid? Does it have to be a certain brand/type?
To my knowledge all front loading washers require low sudsing high efficiency (he) detergent and these only come in liquid. A powdered detergent could probably be used, but I'd try a 1/4 of the recommended amount for a normal load first. Also it is not recommended. Regular liquid detergent can also probably be used but i'd start with 1/2 the the amount for a normal load. If you don't use the recommended "he detergents" expect occasional oversudsing problems and possibly even early drain pump death. Hope this helps.
Here is the owner's manual for your machine:
http://www.managemylife.com/mmh/owner_manuals/25710/ARISTON-Laundry-Centers-L0520687
Jan 12, 2013 | Ariston Technologies Ariston AWD12 Front...
What is the partion insert for the washing powder container for?
Welcome to FixYa.
That is the Liquid detergent partition...P/N 8061633. ( part number )
**This from ASKO...
Because ASKO washers use less water than conventional top-loading washers, you need less detergent and fabric softener. We recommend that you use a low-sudsing powder detergent only, preferably a high-efficiency (HE) detergent designed specifically for front-loading washers.
**(Liquid detergents tend to suds more, which make them more difficult to rinse out.)**
Detergent - The amount of detergent needed varies, depending on the detergent you use. For high-efficiency detergent specifically for front-loading washers, you should use the amounts recommended by the manufacturer.
Also, the amount of detergent needed can vary due to differences in water hardness. (Refer to the Use and Care Guide for more details.) If you choose to use a liquid detergent, start out with a very small amount, such as one or two tablespoons.
Hope that answers your question, let me know please.Thanks for choosing FixYa for your repair solutions today. Let me know if you need further assistance.
Please take a moment and rate the solution provided for you as well as a testimony if you feel it warranted.
Good luck.
Regards,
Macmarkus :)
Oct 22, 2010 | Asko W6021 Front Load Washer
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
How to use liquid detergent and powered bleach?
You should be using a HE liquid detergent. Does you machine have a dispenser for that? The detergent should go in that dispenser. You can put the powdered bleach right into the drum before you load the clothes. I am assuming this is an all fabric bleach.
Happy Clean Clothes!
Aug 18, 2008 | Kenmore Elite 45986 Front Load Washer
Stuck on SUDS
my wife runs into the same problem, sometimes she reruns the cycle and sometimes it continues itself. i am presently trying to solve it. she thinks it might be the detergent, she is useing gain powder and liquid.
Sep 22, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
496 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
