LG WM2277H Front Load Washer Logo
Posted on Nov 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every other load we have OE coming up, also the drowm will not spin
Terry Parish
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 20, 2013
Terry Parish
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
333
Points
I Had this problem with my washer and fixed it by running dishwasher & wash machine cleaner through it I purchased at walmart. start a cycle with the cleaner in it then pause the washer after 2 to 3 minutes and let set for 4 to 5 hours then restart and let the cycle finish . then repeat 2 or 3 times after 2 months the error still has not returned.
Richard Roth
Level 3:
Top Expert:
  • LG Master 9,472 Answers
  • Posted on Nov 28, 2010
Richard Roth
LG Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2627055
Points
28464
LG washing machine error code - OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc
2answers
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
3helpful
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
My lg washer will not spin out it keeps flashing OE no matter what i do
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
2helpful
Oe message doesn't spin
This LG technicians service manual will help you access the drain pump for service and possibly the door switch for repair.
http://136.166.4.200/contents/Laundry/WM1815/WM1815_Service_Manual.pdf
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
