Question about Hasbro Fur Real Friends Smores Pony
Our furreal butterscotch pony has a broken
    Habit-Forming:
    New Friend:
  • 23 Answers
Can you be more specific? Is the neck broken? Or just the ears?
Posted on Mar 18, 2018
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Furreal Pony neighs like a broken record
I had the exact same problem, and all I did was replace the batteries. It worked right again! I just knew the kids had broken the neck of it. It sort of slings to the left and neighs over and over again. BATTERY ISSUE :) The instruction manual should tell the consumer this. Hope this helps!
Posted on Dec 29, 2008
Anonymous
  • 8 Answers
SOURCE: Hi, Where can I buy a new tail for my
Not sure where to buy a replacement but I just fixed mine today. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Posted on Jul 23, 2010
Anonymous
  • 8 Answers
SOURCE: Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
lisaf
Lisa Fletcher
  • 47 Answers
SOURCE: How do I reassemble the head of the FurReal Pony?
The Pony Care Guide refers to an "Assembly Video" on the FurRealFriends.com site. I couldn't find it and even went through a gazillion videos on YouTube. Contact Hasbro directly through this link to see if they can send you a link to the Assembly Video:
http://www.hasbro.com/customer-service/phone-directory.cfm
Posted on Nov 28, 2011
Can I buy carrot and brush for furreal butterscotch pony
Hey, replacement parts for Butterscotch can still be found on ebay, here's one: https://www.ebay.com/itm/263543016418
Sep 13, 2014 | Hasbro Furreal Friends Butterscotch Pony
I need an ear for Butterscotch pony 76471
Hey, replacement parts for Butterscotch can still be found on ebay, here's a left one: https://www.ebay.com/itm/263517990851
May 04, 2014 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony
Hey, the blue and grey wire under the neck fur does not connect to anywhere. It was likely a debug port while Hasbro was testing the ponies. You can try moving the ear by hand when it's supposed to move but it is likely broken inside the head and would need a lot of work to repair.
Jan 06, 2013 | Hasbro Furreal Friends Butterscotch Pony
How to get into and fix tail doesnt move anymore
Here is a link to instructions for removing the fur from the FurReal Friends Butterscotch Pony. Beyond that, I have no idea how to fix a broken tail. If you can find somebody who works on robotic/animatronic toys, or a good handyman, they can probably fix it for you.
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/?ALLSTEPS
Dec 22, 2011 | Hasbro Fur Real Friends Smores Pony
How to fix a broken tail
Call Hasbro Customer Service / Replacement Parts. Hasbro is out of stock on A LOT of stuff, especially the extras like carrots and brushes, but they may be able to send a replacement tail. If you have the tail and can see the break, it may be possible to fix, but you'll need a plastic:plastic epoxy (I can recommend). Do you have pictures? You can contact Hasbro CS directly at 1-800-327-8264 :)
Dec 01, 2011 | Hasbro Furreal Friends Butterscotch Pony
Where can I obtain a complete new tail for my butterscotch pony
Here is a printable form, from Hasbro, for replacement parts for the Butterscotch Pony: http://www.hasbro.com/customer-service/orderform.cfm?sku=76471 ...but I don't think they do replacement tails. This is their Customer Service phone number 800-255-5516.
May 04, 2011 | Hasbro Furreal Friends Butterscotch Pony
I need to replace an ear on my Butterscotch pony
Were you ever able to locate an ear for this horse? Hasbro doesn't sell them anymore... I need one too, so if you found a source, PLEASE SHARE!!! Best of luck!!
Sep 06, 2009 | Hasbro Furreal Friends Butterscotch Pony
Hasbro Fur Real Friends Smores Pony Logo
143 people viewed this question
Top Hasbro Toys Experts
Marvin
Marvin
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
