Front loaders use less detergent and when there's more than the recommended amount, they tend to foam up and cause this. Another issue could be that you're using He detergent and this is a concentrated detergent. The He detergent is recommended for most front loaders and you should only use the recommended amount or foaming will occur.
The last potential issue could be related to a water softener if you have one. If you do have one and you just recharged it, it could be making the water soft-er than normal and this would cause some excess foaming. Soft water is good, but the you need to use less detergent or it will cause this foam issue
Hope this helps.
