Transcend (589307) Media Logo
Posted on Nov 26, 2010
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1381
Points
Jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Dave Sheedy
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Mar 15, 2015
Dave Sheedy
Contributor
Level 1:
New Friend:
Answers
15
Questions
Helped
16024
Points
42
Anonymous
Level 1:
New Friend:
  • Posted on Aug 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1381
Points
My pendrive is 0 byte space problem
1 Related Answer
Anonymous
  • Posted on Oct 05, 2009
SOURCE: pen drive is showing o bytes
ple hielp me my email id is [email protected]
Transcend jet flash v33
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
No space found in my pen drive
your pen drive has bad sectors.Try repairing it by typing chkdsk x: /f /r (where x is the pen drive) at the command prompt
Pen drive showing 0 byte
Do not use any more and get some data recovery freeware.
2helpful
2answers
Transcend 8GB JetFlash V30 Pendrive Device shows Used Space and Free space 0 bytes.
There are two possible
1. Damage to partition table
2. Damage to firmware
To fix the Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
3answers
32gb SD card is showing 0 bytes used space and 0 bytes free space
Try formatting the card and be sure the locking switch is in the off position.
2answers
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
3answers
On opening a pen drive it is showing 'please insert a disk into removable disk (h:)' and opening its properties it is showing used space 0 bytes free space 0 bytes
Hello there yogeshpat876.
Here's your geek-steer ...
Is this a new drive? If so, it probably just needs to be formatted [and optionally assigned to whatever free drive (letter) you desire]:
Start > Run... > tpye "diskmgmt.msc" (without quotes), then OK
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
2helpful
2answers
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
2answers
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
