SOURCE: Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
SOURCE: NO ICE - IC6
Mine was slow-to-none in ice making for a couple of years. One day for the first time I used the built in water dispenser. The long copper line feeding water was full of air gaps. After I bled that out, it has been perfect ever since.
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
SOURCE: Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
SOURCE: amana ice-maker
Very curious. When you say the tube to the ice maker was disconnected I am unsure as to which tube you are refering to. However hopefully a few pointers might help a damsel. Most units have the water supply enter into the cabinet through a two way water solenoid valve (i.e. one for chilled water one for the ice maker). It then normally enters the top of the freezer section for the ice maker. It then drops down inside the freezer section to the icemaker module. Therefore the only control over the water for the icemaker is the solenoid valve which is controlled by the icemaker "module". A trick is to switch the control at the solenoid valve so that you can use the chilled water dispenser to check if the water valve for the icemaker is working. If it is then you probably have a problem with the icemaker module or the temperature in the freezer section (which you would probably have noticed if that was the case). If you have a problem with the module then you normally have to replace the module as they dont like supplying spares for modules.
Anyway hope this is of some help and good luck.
ps model is normally near the salad drawer or top of the fridge section dependent on brand.
