Question about Samsung RS2630SH Side by Side Refrigerator
My refrigerator has been in storage for 6 months, was working ok before we stored it, except for the ice maker. It never worked properly since day one. Any ways now we have moved into our home and the refrigerator will not cool. We push the power freeze and it just goes back down. It has been plugged in for a week now and the freezer and frig just are a little cool almost room temp. Is it worth fixing and how much should it cost?
    Top Expert:
  • Samsung Master
  • 85,216 Answers
The cost for a service call is about $100 and then labor you may end up with a bill for over $500.00 USD
Posted on Jul 07, 2017
6ya staff
SOURCE:
Anonymous
  • 150 Answers
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
Posted on May 08, 2008
Anonymous
SOURCE: samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Posted on Jul 28, 2009
Anonymous
  • 42 Answers
SOURCE: Frig is only cold on the bottom of the freezer
check evaporator fan motor in the freezer if it running
Posted on Aug 01, 2009
mgprice
Mike Price
  • 744 Answers
SOURCE: whirlpool side by side; frig is not getting cold,
Hi, With the information you supplied I’m going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself.
This is going to be one of three problems with your refrigerator, 1st thing to do is remove shelf’s and panel in the back of the Freezer. You may see ice build up on the evaporator, don't worry get a hair dryer and melt the ice.
Next locate the wires for the defrost heater and using a multi-meter/ohms meter test the heater for continuity (it should read infinite) if the defrost heater is bad replace it.
This is what a typical defrost heater looks like:
If the heater is good test the defrost thermostat. This should normally be done when the evaporator is still covered with ice since it will only activate at 40f - 50f depending on the thermostat. When tested with the ohms meter at below 40f it will read infinite. It is normally clipped to the upper right of the evaporator and look something like this:
4462625.jpg The next possible problem could be the defrost timer. If you have tested the heater and thermostat and they have tested good next find the defrost timer, If your refrigerator has a mechanical one it will either be located inside the control panel in the fridge or behind the panel below the doors. Once you have located it advance the dial until you hear a click. This will initiate the defrost cycle. If your heater begins to get hot this will tell you that your timer has stalled and needs to be replaced. A typical mechanical timer looks like this:
f218caf.jpg If your refrigerator has a digital defrost timer you should locate the tech sheet. Normally you can find this behind the panel under the doors. It will tell you how to initiate a manual defrost cycle. As before if the heater gets hot you will have to replace the mother board2.gif normally located behind a panel at the rear of your refrigerator.
If your fridge is warm and there is no build up of frost/ice on the back panel inside the freezer then you problem is most likely going to be the evaporator fan, have you heard the fan running in the past few hours? if you are not sure pull the panel out to where you can see fan and watch it over the space of an hour to see if it turns. If you don’t see it turning replace the motor. This is what a typical evaporator fan looks like:
a4183d8.png Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using Fixya! Mike
Posted on Nov 03, 2009
John Hall
  • 1218 Answers
SOURCE: we have a roper frig that we use for vaccine
Good day,
Usually caused by the machine in a cool area or room, along with the machine not getting enough door action, both freezer and fresh food.
Domestic refrigerators are designed to be used as just that. Domestic refrigerators.
Normal kitchen temperatures, followed by minimum of 7 freezer door openings per day spread over 14 hours as well as 22 to 26 fresh food door openings over the same period of time.
In other words, it's not getting enough activity daily. Common problem in doctor offices.
The best model for that type of application in the past was the Amana bottom freezer model. where the primary control was located in the freezer, nailing the freezer temp, and the top controlled by a pneumatic damper controlling the fresh food section, but I do not know if their current model still uses that system.
One option,space permitting is a small chest type freezer added to what you have.
Posted on Mar 15, 2010
Compressor will not start on a frigidaire refridgerator
The compressor gets power from compressor capacitor or compressor relay.On some models there is capacitor and on some there is relay.May be that relay or capacitor got shorted causing the problem.
But if that checks out ok,then its faulty compressor causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Refrigerators
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
These will help.
Thanks,.
Not making ice but water dispensing ok whirpool ed5lhaxwboo thanks for any help
These will help.
Thanks,.
Why does the unit gurgle very loudly throughout the day?
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Maytag PBF2253HEW; freezer fan not working and fridge not getting any cold air. Ice maker only dropping about every 6 - 8 hrs. What needs to be replaced? (This was a friend's refrigerator, he used for 2...
Mark Remove the rear panel in freezer. Apply 3n1 oil to fan motor shaft and plug in and spin. I believe they left the freezer shut and the moisture froze the shaft on fan with rust. Once restarted you will be fine. Sea Breeze
Jan 27, 2010 | Refrigerators
Ice maker doesn't work
Is the filter blocked? If you have not changed it recently (usually every 6 to 9 months) then it will prevent water flow. If this is OK then this is usually caused by the control module or water inlet valve going faulty and will need a service engineer visit. Also check for anything blocking / jamming the auge.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker working very slowly; as else working fine
Change the water filter if it is 4 to 6 months old.
Jul 29, 2009 | Frigidaire FRS23R4A Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
114 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
