Are you going to spend hard cash on this junk
its old and worth Zero
now
try a new battery, oops those are expensive.
i see working
presario CQ50
for $30 working
not working worth nothing
its worth at best the cost of potted plant.
why fool with it>? or spend cash on any COMPAQ.?
got to "GOODwill" fine a 10 year or newer system.
best advice of all that. one that works too.
never put $100 in a $10 box.
a$100 saddle on a $5 Horse "
says grand dad, and was right for 100 years.
both were.
see these never spend more than this, if money is tight.
https://www.walmart.com/search/?query=de...
SOURCE: HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
SOURCE: Compaq presario V2000 doesn't start
you might have shot out your battery because if electrical curent is goging in to the computer (te orange light is going on) but the computer wont turn on it might be a problem with your battey
please rate
SOURCE: compaq presario cq50-100em wont start up
I'm sorry to say this sounds like a system board failure. On my HP DV200t, a very similiar issue occured, eventually only the led where you plug in the power cord would turn blue. I replaced the system board and all the issues went away.
Hope this helps, and I am sorry to be the bearer of bad news.
SOURCE: how to restore to factory settings presario cq50
2 possible solutions to this
1. Use the roll back function of your operating system to roll back to the last back up.
2. Insert your restore disk or Windows disk and do a format/clean install.
If you have a restore disc it will have prompts to "restore" your system and give you a warning about losing data-save off what you want BEFORE doing this restore
If you have standard windows disk you may want to use the format utility in windows first to clean the drive and do a fresh install.
Once installed don't forget to download updates and back up and then reload your other software.
have fun this will take several hours depeneding on the amount of stuff you have to reload and patch up.
SOURCE: my compaq presario cq50 wont turn on has not been
check the power switch or button..
first then if the same. check your board
