Not only do you have a loud roar but it's leaking small amounts of water thru the top seal and into the spin brg . top brg and seal will have to be replaced .. the pump may be ok they donot make noise and the belt is normal mantaince . the idler just oil it . . the parts that you stated are in the lower part of the maching and the brg is just under the outer tub . .. and just for your info the pump runs both in spin and agit . so why does it not make noise in the wash ? so back to basic the top brg is only going in the spin and they get noisey whe water get s in them .. we do a lot of these and trust me the top brg is your problem . mm hope this helps ... feed back pls and thanks for ysing fix ya .
