Washing Machines Logo
Posted on Nov 20, 2010
Repair manual for a LT758S westinghouse washing machine
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1094
Points
5
I have a Westinghouse LT758S 7.5 kg complete care washing machine everytime I turn my washing machine it will flash wash so I press start, it will beep 6 times and the medium and high lights will continue flashing on the water level??? I tried turning it on off but nothing what should I do?
  • Anonymous Nov 27, 2011
    So what is the answer. I have the same model with the exact same problem.
Westinghouse LT758S Washing Machine
It is a lid switch issue. I has a magnet and a reed switch.
Westinghouse washing macjhine Lt608s goto start beeps & ...
JustAnswer https://www.justanswer.com > Australia Whitegoods
Oct 23, 2012 - The 3 water level light does indicate the Out of balance switch as faulty, if it is accompanied by 15 beeps. 5 beeps means the lid switch = LD.
1 answer · Top answer: Hi Craig Lets not give up just yet. So you have replaced the out of balance s
Lt758s push start wash blinks and machine beeps 6 times and medium and high level lights blink and Machine won't go
Owner's manual troubleshooting should help. No Owner's manual? Try MFG website, or email their customer service, or try: manualslib.com You may be able to find a "repair" manual via google search for machine and error codes.
Where can I find the manual for WHITE WESTINGHOUSE model WW105. Thanks in advance.
Options I can think of:
1. Contact your local Westinghouse reseller, and ask them to purchase it
2. Contact Westinghouse directly http://westinghouse.com/customer-care/
3. Use their troubleshooter here http://www.westinghouse.co.nz/Troubleshooter
Westinghouse LF708B washing machine wont spin,drains but wont spin Use to work when you thump machine but now wont spin at all
I have found that it is a blockage I manually drain the water through the botton of the machine then the cycle continues as a short term fix. I am not a professional though
Manual for westinghouse lt959s
Hi, our lt959 is tripping the power mid cycle. just wondering if any one can help...
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Top Washing Machines Experts
john h
