Ford Master
- Posted on Nov 19, 2010
Re: How to change a front turn light in a 1996 taurus.
Lamps, Parking
Front Lamp-Lamp Assembly, Taurus
Removal and Installation
Remove Headlamp (13008) as outlined.
Headlamp Assembly
WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
Position headlamp switch (11654) and headlamp time delay switch (13736) in the OFF position.
Remove two bolts retaining headlamp (13008) to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle.
Remove park lamp bulb and socket (Sable only) and headlamp bulb and socket from Headlamp Assembly as outlined.
Headlamp Assembly (Taurus Shown, Sable Similar)
Turn lamp socket and wiring (13410) assembly 1/2 turn counterclockwise and remove from parking lamp (13200) housing.
Remove screw from park/turn signal housing.
Using 1/4 inch drive socket extension and swivel, insert tool through two access holes in upper radiator support. Remove screws from park/turn signal housing.
Remove parking lamp from vehicle.
To install, reverse Removal procedure.
