Question about Pass & Seymour Trademaster 3-Way 15 Amp 120/277-Volt Decorator Switch, Light Almond #TM873
I cant get both switches to work properly one minute it turns the light on the next they done work. is the red wire suppose to hook up to the black screw
  • Al Kupchella
    Al Kupchella Nov 19, 2010
    If you can provide more specifics, I can help you. Besides the ground wire, do both switches have only three terminals? Suppose switch A is up, does switch B then turn the light on and off? And if switch A is down, does the light remain off regardless of the position of switch B? Any other details you can provide?
The key to three-way switches is the dark screw.
And different brands of switches put dark screw on different side of switch.
So, lets get out of this mess with a bit of testing.
You have two switches with 3 wires on each switch for a total of 6 wires.
Take out both switches and separate wires for testing.
Turn on power and test each wire to bare copper wire.
One and only one wire will test Hot.
The hot wire goes to dark screw on switch1.
The other two wires in that box go to either screw on switch1.
One switch done, one switch to go.
Move switch1 lever to down position.
Turn on power and test 3 remaining wires.
One wire will test hot. Mark this wire.
Move switch1 to up position, and test 3 remaining wires again.
A second wire will test hot. Mark this wire.
The 2 marked wires attach to either brass screw on switch2.
The third wire attaches to dark screw.
Both switches done.
Posted on Nov 20, 2010
6ya staff
SOURCE:
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
What could have gone wrong, disconected the battery and now it does not want to start ?
by disconnecting the battery you may have corrupted the CPU program. Use a scanner to reset the CPU.. Next by fitting the switch you may have changed the system so that you have affected the immobiliser and other components . It may be necessary to remove what you have done and take extra care as to what wires you hook into.
Jul 18, 2014 | 2005 Ford Bantam 1.3i
I just replaced my heater/fan/light in my bathroom. The only thing that confuses me is the red wire that is attached to the unit itself. What if you do not have a red wire ran but there are still three...
I know wiring and we can solve this problem.
A better description of your wires in required.
Then 'add a comment' at bottom of page, and it e-mails me, and then I can hook up the wires for you.
The following 8 questions are key to solving the problem.
The heater-fan-light has how many wires?
Exactly what color are the fan wires?
How many cables enter the fan-light-heater box?
Does each cable have a black-and-white?
Are all these cables from the switches?
Are there other cables that enter the fan-light-heater box?
How many switches control the fan-light-heater device?
Is each switch a simple on-off switch or are there 3-way switches too (a switch at each end of a hall is example of a 3-way switch)
Oct 2010
If you 'add a comment' I'll be here for next 3-4 hours
We'll get it done
Oct 28, 2010 | Broan-NuTone FAN CONTROL SWITCH
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
Light and fan work but does not work with wall switch
This would mean that that constant power to the fan and light is not wired through the switch right, or not wired into the switch at all. Most ceiling fans that have a light kit will have a Black, White, Green, and Red wire that comes from the ceiling and hooks into the fan and light. If it was done correctly, then the Green wire would be ground, the White is your neutral which is hooked to the other White wire, the Black wire is usually power to the light kit which will also hook to another black wire, and the Red is to the fan. Sometimes the Red and Black are reversed. If any of these wires are wired wrong, that could possibly lead to a constant power to the fan and light kit.
Feb 02, 2010 | Hunter Dryers
I'm replacing a single pole light switch with a timer switch and the timer switch comes with a hot (Black) and a Load (Red) as well as the netural (White). My question is how to wire it up. Does the white...
It all depends on how the light on the pole is wired. The switch you have is meant to interrupt the power between the circuit breaker and the light, just like the switch does now. The new switch uses power to run itself, so you need an additional wire. Usually the lights on a pole have the power coming in on top, and a wire coming down for the switch - black and white. Lets say there was no switch - on top of the pole there would be a black wire going to the hot, or center contact on the pole light, and the white wire would go to the ground, or outside of the bulb. If (BIG IF) things are wired like they are supposed to be, there will be a black wire (hot) coming in from the breaker, down the pole, instead of going to the light. The switch you have in place now interrupts the power so you can turn it off/on. Then when you turn the switch on, power goes up the white wire to the hot, or bottom of the bulb. Theoretically, there should be another black wire going back up to power the light once it leaves the switch. People normally use regular wire, which has a black and a white inside a plastic casing. So, bottom line - you need to run a red wire from the light to the new switch, hook the white wire up to the ground. So: power coming in on top goes down pole to new switch to black. Red wire hooks up to pole light where it is now white, goes down pole to red on switch. Old white wire gets unhooked from light on top, and hooked to common (ground) on top.
Aug 31, 2017 | Globe Electric Globe Indoor/Outdoor Lights...
2002 malibu wiring diagram?!?!?!?!?!?!
ok, the red and yellow wires serve 2 different purposes.the yellow supplies constant power to your stereo, and the red is switched power. what youve done is combine the two, and connect them to a constant power source. like this, your stereo wont be switched with your ignition. so take off the red wire, but leave the yellow wire connected to the wire its already on. make sure your stereo fuse is good in the fusebox of the car. then, use a test light, with the ignition switch on, to find the second wire on your cars harness that has power. that will be your switched power. connect that one to your red wire, and that will solve your problem.
Aug 04, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
Oct 08, 2008 | 1993 Ford Explorer Limited
After market radio wires causes light issue with light switch
check your ground on the radio......... the feed from the lights will test as a ground and the radio will use this as a circuit and turn on the lights. been there done that what a nightmare
Oct 02, 2008 | 1996 Dodge Dakota
Pass & Seymour Trademaster 3-Way 15 Amp 120/277-Volt Decorator Switch, Light Almond #TM873 Logo
711 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
Mike
Gil Shultz
lakeareaserv
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
