The part that is in the pan will not turn. I have tried vegetable oil and it is frozen. The part that is attached to the machine turns and the paddle itself seems OK. Any suggestions? Is it possible to buy a new pan? I use my machne several times a week and will miss it!! diane [email protected]
SOURCE: The 5891 has an O-ring seal inside that helps
Hi, I have looked to expecting to find one but ran into the same thing you did. I didn't try Sunbeam Oster though, maybe they would have one. I buy and sell and repair bread machines sort of as a hobby. If you ebay, I have a cuisinart and your model of sunbeam up for sale this week. If you ebay and are interested in just getting a replacement machine the one I have advertised has never been cooked in so the pan is new. If you ebay just type this Item # in the ebay search bar:
260688801609
best wishes and happy breadmaking!
The turning mechanism on my pan is also having problems. I've tried several different things to get it to rotate easily again and haven't been successful. I would like to get another pan to be able to use the machine again, but haven't been able to find a replacement.
Paddle will not mix. I set up my machine, all the ingredients were in the bucket. It started to mix but sometime after the first mixing section and the second it stopped. I could not get it started again. The bucket paddle moves, but not the mechanism within the base machine. On the LCD screen display I see an HHH. What's my next step? Thank you...Jill
I haVe the same problem we hit the start button, and all we get is HHH
Did you get a solution.
Thanks
The paddle mechanism won't turn, and the machine just goes clunk when I turn it on. Worked fine the other day.
