JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
Posted on Aug 16, 2017
Green Tint when TV turns on with no red color on tv screen. Just replaced lamp 2 weeks ago w/phillips. JVC HD-52Z575. Tried to adjust everything in the menu option to no avail. Thought it was the lamp but, the store's tech said it may be a color wheel issue. Did research and this tv does not have a color wheel. Can there be any other issue or a part that is easily replaced? Thank you
5 Related Answers
A
Anonymous
  • Posted on May 11, 2008
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
A
Anonymous
SOURCE: JVC HD-ILA PROJECTION T.V. #HD-52Z575
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Anonymous
  • Posted on Aug 28, 2009
SOURCE: Lamp and Power lights blinking fast and no picture...
hi mach500..We just had the same problem. Did you find out if it could be the fan?
Thanks
Anonymous
  • 456 Answers
  • Posted on Dec 05, 2009
SOURCE: rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Anonymous
  • 5138 Answers
  • Posted on Jan 25, 2010
SOURCE: I just replace the bulb in my JVC HD-52Z575
Ballast Board? it is what Powers Lamp, or CK Lamp Fan if it stops running and is not Keeping Lamp Cool
set is designed to shut off to Protect lamp from being burted up, you could have either Bad Ballast Board or Defective Lamp Fan,there is a few test you can do to see which Part is Bad.
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
JVC HD-52Z575 TV that has briteness an color purity problems.
From what little I have read about these TVs parts are High Call JVC 1-800-233-1060 Ask for TECH surrport them them what your problem is If it doe turn out to be Light engine Call UED for price of rebuilt one 1-800-648-6657 Also go to website ENCOMPASS look up your Model number they will have a listing of Parts 1-800-638-3328 You can try Downloading to USB stick in formation to it reprogram eeprom to TV sometime this will correct problem! GOOD LUCK with the repair.JVC downloads.
1helpful
2answers
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Green color on Samsung ln-t4042
If the whole screen has this tint problem, there is nothing you can do. It must be repaired. You will need to take it in for service.
1helpful
2answers
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
