You would remove the bottom access panel
More repair photos and a service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hi
F21 error means that the drain time has exceeded 8
minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to
clear the display. If errors still remains then please check the drain hose and
make sure it is not plugged or kinked. Disassemble the washer by removing the
back from the washer and check the electrical connections at the pump and make
sure the pump is draining. Also inspect the pump filter for foreign objects.
Before disassembling remember to turn off the power and disconnect the washer.
If it still doesn't help then there is an issue with the pump and you'll need
to replace it. Hope this helps... Please post back if you need more
information.
Daniel
