Fisher Price Power Wheels Cadillac Escalade Logo
Posted on Nov 15, 2010
How do I switch from low to high speed on a Jeep Hurricane. Shifter won't go into forward slot.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
709
Points
I have NO CLUE but it bet its a simple piece of Chinese plastic. Look down at the shifter, USE screw driver to remove shifter, remove Chinese plastic blocking the shifter from being pushed into HIGH by young child. Reattach shifter, push shifter forward to HIGH.
96 ROVER DISC. Has strong reverse - won't engage any forward gears. Fluid seems full even when warm.
Make sure the 4wd shifter is in correct position and hasn't slipped out of correct spot to get you moving forward.
Does not operate in reverse
If the vehicle will not go in reverse, but works in both low and high forward speeds you most likely have a bad shifter switch.
The shifter switch is only available in a shifter assembly found here: http://www.mendingshed.com/j4390-9209.html
Replacing the shifter should get your Power Wheels running correctly.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jeep hurricane will work in reverse but will not go forward
pull the shifter switch and verify that it is connected underneath
May 31, 2012 • Toys
Reverse and 1st gear work but 2nd gear does not
might be a dumb ? but is the limiting screw still in the shifter? if not youve got a switch issue, here is a link to get a high/low switch for $11. to install, remove the shifter...1 screw in the back side and slide it forward. the high low is the one toward the rear.
good luck!
39helpful
10answers
Little Tikes Hummer
Its the battery, you can purchase new one on amazon. here: Amazon com little tikes hummer battery. I hope this was helpful. cheers
No high speed on my TCV 6V ride on car
Try to check the forward terminal connection high speed going to batterry, possible of loose connection.
2answers
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 • Toys
1helpful
3answers
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 • Toys
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
