Perhaps you have forgotten to unplug the scanner before scanning? That's
what happened to me. I kept getting different error codes, 5,202,63 or
5,202,52 or 5,202,54 and also a message that the driver was not in the
TWAIN folder. According to the help file the problem might have been due
to my nfts file system. I also tried downloading various new drivers.
Nothing helped until I noticed that I had not unplugged the scanner!
Perhaps you have forgotten to unplug the scanner before scanning? That's what happened to me. I kept getting different error codes, 5,202,63 or 5,202,52 or 5,202,54 and also a message that the driver was not in the TWAIN folder. According to the help file the problem might have been due to my nfts file system. I also tried downloading various new drivers. Nothing helped until I noticed that I had not unplugged the scanner!
TO ANYONE READING THIS...I nearly took a hammer and smashed my Canon
LIDE 110 Scanner cause I was so mad that it gave me this stupid error
(5,202,52) no matter where I was connecting it and I thought it was
done...
THEN I just took another USB Cable (Like I have around 10 different USB
Cables) ...AND IT WORKED! Try several USB cables before you give up on
it...also don't start messing around with drivers and stuff, you could
end up screwing up your system like I did...
I hope this helps someone out there in the future with error 5,202,52 or 5,202,54, etc.
Try at least 4-5 different USB cables before anything else..
(If you want to know, I successfully used the USB cable with one of the
fat black circle things on it (I think its for power or something), not
just a straight usb cable. It's still a 5 pin USB cable however
(Regular USB on one side, small 5 pin connecter on the other side))
ive been resolving that issue for almost 8 hours since last night.(that means i did not sleep) because i badly need to scan papers for my precentation today. finally it worked after unstalling all canon folders, then reinstall everything... hope this work with you
TO ANYONE READING THIS...I nearly took a hammer and smashed my Canon LIDE 110 Scanner cause I was so mad that it gave me this stupid error (5,202,52) no matter where I was connecting it and I thought it was done...
THEN I just took another USB Cable (Like I have around 10 different USB Cables) ...AND IT WORKED! Try several USB cables before you give up on it...also don't start messing around with drivers and stuff, you could end up screwing up your system like I did...
(If you want to know, I successfully used the USB cable with one of the fat black circle things on it (I think its for power or something), not just a straight usb cable. It's still a 5 pin USB cable however (Regular USB on one side, small 5 pin connecter on the other side))
all i am getting is advertisements that can "fix" my computer at a price, everywhere says there is a driver out of date but nowhere tells u how to fix it
its a cannon mp250 throwing up error5,202,54 when trying to scan
Go to Device Manager at USB Controllers and disable Standard Enhaced PCI to USB Host Controller. If you can't find exactly this, disable the one with the word Enhaced in it. Right click it then click disable.
