Inside the machine is two carbon electrodes that ignite the fuel and if they are burnt away it will not work ,check the electrodes and make sure they are sparking across but then try it with the cover off as the air flow stops them from sparking if the coil is low or the gap isnt right .This is the most common cause of problems with these machines ,also the same problem with steam cleaners as well
