Your problem could be cause by either, both or neither. Start by checking the easiest things first. Check that the spark plug wires are connected in the proper firing order. The firing order is 1-3-4-2.
Next check that all of the plugs that were removed are firmly plugged in. Even check the ones you did not remove, just in case.
Next check that you get fuel and spark. Although it is not conclusive, if you smell fuel out of the exhaust, you are probably getting fuel. The best way is to use a fuel pressure gauge to make sure you are getting fuel at the correct pressure. Typically, base fuel pressure is in the neighborhood of 42 psi with the vacuum line disconnected from the pressure regulator. For spark, a quick test is to remove a plug, connect it to the spark plug wire, firmly ground the metal body of the spark plug, crank the engine and observe the gap for spark. This does not tell you the quality of the spark, it only tells you that there is a spark being produced but may not be hot enough to ignite the fuel. If you are not getting a spark, troubleshoot and repair before proceeding.
If all of the above have been done and it still does not start, than check that the timing marks line up.
Post up a follow up if the timing marks are lined up properly.
A car that cranks over but doesn't start, in many cases will be due to a bad fuel pump, a broken timing belt, an inoperative cam sensor or crank sensor. Also these problems are related to faulty spark plug. Check the spark at spark plugs when you start the car. Do you notice any spark. Actually you should see. If in case there is no spark then it's a spark plug problem. Also the coil pack gives power to spark plug. So check the voltage at coil pack. It will show 12 volt. If there is no voltage noticed at coil pack then its faulty coil pack that has to be replaced. If all the possible options checked out ok then check the car starter. The starter gets power from battery to start the car. If the starter is faulty then it will not let the car to start. Also check and confirm that there is fuel in the car. If its very low fuel then in some cases this causes the problem. Also check and confirm that fuel pump is functioning properly and the fuel filter is not clogged. One of the easiest ways to check for a fuel pump related problem is to spray a little starting fluid into the air intake while trying to start the car. If the car starts momentarily, then there's a good chance the fuel pump is not working or the car is out of gas. You can also listen for the fuel pump's humming sound when the key is first turned on. Also if a inoperative fuel pump is suspected, a good technician will always check to verify there is power and ground being supplied to the pump, to eliminate the possibility of a bad relay or electrical issue. Fuel pressure can be checked with a pressure gauge and if there is pressure, pulse can be checked at the fuel injectors in several ways including the most common, with the use of noid lights. If the injectors don't have pulse the engine won't start. ---------- This troubleshooting tips will help you to solve the problem. Thanks. Helpmech.
In many cases this will be due to a bad fuel pump, a broken timing belt, an inoperative cam sensor or crank sensor. Also this problems are related to faulty spark plug. Check the spark at spark plugs when you start the car. Do you notice any spark. Actually you should see. If in case there is no spark then it's a spark plug problem. Also the coil pack gives power to spark plug. So check the voltage at coil pack. It will show 12 volt.If there is no voltage noticed at coil pack then its faulty coil pack that has to be replaced.If all the possible options checked out ok then check the car starter. The starter gets power from battery to start the care. If the starter is faulty then it will not let the car to start. Also check and confirm that there is fuel in the car. If it very low fuel then in some cases this causes the problem. Also check and confirm that fuel pump is functioning properly and the fuel filter is not clogged. One of the easiest ways to check for a fuel pump related problem is to spray a little starting fluid into the air intake while trying to start the car. If the car starts momentarily, then there's a good chance the fuel pump is not working or the car is out of gas. You can also listen for the fuel pump's humming sound when the key is first turned on. Also if a inoperative fuel pump is suspected, a good technician will always check to verify there is power and ground being supplied to the pump, to eliminate the possibility of a bad relay or electrical issue. Fuel pressure can be checked with a pressure gage and if there is pressure, pulse can be checked at the fuel injectors in several ways including the most common, with the use of noid lights. If the injectors don't have pulse the engine won't start. ---------- This troubleshooting tips will help you to solve the problem.Thanks.Helpmech.
Most probably its a low fuel pressure related problem.Get the fuel pressure checked.If its low then this is faulty fuel pump and clogged fuel filter issue.the other possibilities are,-----
A car that cranks over but doesn't start, in many cases will be due to a bad fuel pump, a broken timing belt, an inoperative cam sensor or crank sensor. Also this problems are related to faulty spark plug. Check the spark at spark plugs when you start the car. Do you notice any spark. Actually you should see. If in case there is no spark then it's a spark plug problem. Also the coil pack gives power to spark plug. So check the voltage at coil pack. It will show 12 volt.If there is no voltage noticed at coil pack then its faulty coil pack that has to be replaced.If all the possible options checked out ok then check the car starter. The starter gets power from battery to start the care. If the starter is faulty then it will not let the car to start. Also check and confirm that there is fuel in the car. If it very low fuel then in some cases this causes the problem. Also check and confirm that fuel pump is functioning properly and the fuel filter is not clogged. One of the easiest ways to check for a fuel pump related problem is to spray a little starting fluid into the air intake while trying to start the car. If the car starts momentarily, then there's a good chance the fuel pump is not working or the car is out of gas. You can also listen for the fuel pump's humming sound when the key is first turned on. Also if a inoperative fuel pump is suspected, a good technician will always check to verify there is power and ground being supplied to the pump, to eliminate the possibility of a bad relay or electrical issue. Fuel pressure can be checked with a pressure gage and if there is pressure, pulse can be checked at the fuel injectors in several ways including the most common, with the use of noid lights. If the injectors don't have pulse the engine won't start. ---------- This troubleshooting tips will help you to solve the problem.Thanks.Helpmech.
