Buy whatever kind you prefer. On an open coil unit it really does not make much difference. On a smooth top, Make sure it has a flat bottom, preferably dark, not shiny. On white smooth tops avoid aluminum as it leaves grey marks.
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
See the link below, then click on the exact model number for your appliance when the page appears. Then see the specific section for the part you require:
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
Hi, interesting. I have the same units on my GasHob and my problems are exactly reverse. To turn the burners on it takes about 15 clicks and with some luck you'll get gas! Sorry, wished I could help. Claus.
If you're talking about a downdraft style cooktop, you will just need to measure the discharge vent diameter and shape and match that up. Not all are the same shape but most are 6" diameter
