SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Sounds like a possible main control card issue. If this machine is under warranty please call your dealer as these boards can be expensive.
SOURCE: paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
SOURCE: fisher and paykel toploader will not start!
quite likely the motor controller has died, which is situated underneath the control panel.
SOURCE: after washing my fisher paykel toploading washer
possible a blocked pump , it shud beep , come up with a code read the 8 lights on the top
SOURCE: my fisher & paykel smartdrive 5.5kg toploader
Sounds like problem with inlet valve solenoids. There is one for the hot, and one for the cold. Fairly easy to replace if you are a confident DIYer- Disconnect from power, remove two screws holding top control panel on. You will see inlet valves on left hand side (the inlet hoses are attached to the valves, so you need to unscrew hoses). Two screws on rear of valves to remove grey plastic retainer, then valves pull up to remove. There is a rubber grommit on bottom of valves- retain this as some new valves do not come with this piece. New valves available from any good appliance repair shop. Call in the experts if you are in any doubt!!
