Irwin SDS-Plus Hammer Drill Bit 6in.L, 1/4" dia., ModelNo. 322017 Logo
Posted on Nov 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sd rotary hammer drill 110 volts bit brocken in chuck
EugenesDIYDen
Level 3:
Guru:
  • Master 479 Answers
  • Posted on Nov 27, 2010
EugenesDIYDen
Master
Level 3:
Guru:
Answers
479
Questions
Helped
328565
Points
1212
Put some WD40 into chuck and wait a few minutes. Open the chuck as you would do when normally removing the drill while at the same smartly tapping the back of the drill.Alternatively try to grip the broken drill bit with a long nose pliers to extract it. A strong magnet might also pull the bit out.
Inserted incorrect drill bit into my stramm 800w rotary hammer now i cant get it out what can i do
Hold the drill bit with bench wise jaws at up wright way and keep a piece of wood log with chuck head & give it a hammer shot opposite way.Be sure to loosen chuck fully anti-clock wise.If your drill chuck pull releasing type you have to pull it and put a brake on it.
1helpful
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
1helpful
Drill bit seems to wobble on normal drilling function (over rotates at tip of bit)
could be a bent bit... if its not its gotta be your chuck or the screw that holds it on
Drill bit stuck in chuck
Grab the bit and see if it will move in or out of the chuck around a half inch. If the bit will not move at all inside the chuck at all. Lock the bit in a vise and strike the chuck with a rubber mallet. This will usually get the bit out.
How do u fit a drill bit into a rotary hammer drill model number fmtc850rhd
Pull back on the chuck and then turn the bit til it drops in place, release the chuck and it will hold the bit...
heatman101
There is play in the chuck may be bearings. it means drill bit wanders slightly when drilling. drill bits lock in properly but the chuck has left to right play in it
You seem to have found the problem, now you must disassemble the gear head and remove the chuck. Open the chuck jaws wide and look for a screw inside that locks the chuck to the shaft.
3helpful
3answers
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
1helpful
Hammer drills types
Two drive systems are available on both the hammer drill and the rotary hammer models: 1. SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. 2. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Top Irwin Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you an Irwin Drill Expert? Answer questions, earn points and help others
