I am unable to print any thing from my computer. I geta message that the installation is incomplete and to reinstall the program disc. I have lost it, and need to get another.My Printer is HP C5250 all in one printer/ scanner/ copier. Can you provide me with an installation disc. Thank you
If you recently installed the printer or other programs in your computer then this problem occured. You may just need to reinstall the printer on your computer with your disc that came with the printer. What may of happened is that the program or updates that were installed deleted your print driver. To fix just reinstall and you should be fine. This is nothing you did wrong just the way things happen. Also you can check in your control panel and make sure your printer is turned on as your default printer.
Solution You must reinstall Microsoft .net framework.
You can do this by: Go to the control panel Go to add remove program select Microsoft .netframework 1.1 and remove Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by: Insert the Print Shop Install disc Double Click on My computer Right Click on the Drive that contains the Print Shop Disc Left click the open option. Double click on the folder called Setup Double click on the file that’s called 1033DotNetfx This will reinstall the net framework on your computer and it should fix the issue you are having.
When you reinstalled it did you unplug it from the computer. Often links to printers are lost, it's a Windows thing, frequently people reinstall in desperation, forgetting to uninstall the original and disconnect the printer USB. So, unplug the printer USB from the computer, go to control panel,and printers and delete the printers that you are going to reinstall which you see there. Then go to add and remove programs and remove all software. If there are print jobs pending you may not be able to uninstall or delete, so click the printer and delete all jobs pending, then try the uninstall again. When all is uninstalled, restart the system and reinstall, plugging in the printer only when the software asks for it. It being an HP the uninstall option may well be on the installation disc so you can use that if you wish.
