Hitachi 55HDS69 55 in. Plasma Television Logo
Posted on Jun 16, 2008
Hitachi 42" Plasma HDTV
I am getting either red or blue lines down the center of the picture. It doesn't happen every I watch tv. It even shows up when I play a dvd
Anonymous
Level 1:
Dedicated:
Visited the website for 20 consecutive days.
Passionate:
Visited the website for 10 consecutive days.
  • Contributor 14 Answers
  • Posted on Jun 25, 2008
Anonymous
Contributor
Level 1:
Dedicated:
Passionate:
Answers
14
Questions
Helped
7762
Points
26
This happened to me with my first Hitachi 55" plasma. It ended up being the panel itself, which was very expensive to fix. Thankfully mine was under warranty and I was able to get a replacement TV.
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
3helpful
3answers
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
42" Dell plasma TV
Y SUS and Buffers are usual culprit.
You can get it from guy at
[email protected]
He has everything for Dell TVs
Floating Horizontal Line
Sounds like a bad component on the video board. These days, TV techs just swap out boards for whole new ones.
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Red outlines in the picture
somewhere in the tv menu there is a place to make video adjustments. one should be for aligning the color guns. one is for red and the other two are green and blue. it will give you a cross in the center of the screen. it should also give you prompts to adjust the lines for centering and to save changes. this happens eventually on all rear projection tv sets.
3helpful
2answers
My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
