GE Profile 22.2 Cu. Ft. Bottom-Mount Refrigerator - Stainless-Steel Logo
Posted on Nov 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bottom Freezer Profile fridge does not cool properly in the fridge portion. Freezer works. Compressor works draws 1.1 Amps at 120 Volts. Evaporator Working fine Condensor coils clean Condensor Fan Works No Visible leaks Suspect Evaporator Fan
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Nov 07, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10845044
Points
101584
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
DEFY C305 combi top fridge bottom freezer FAULT:freezer operates ok, but fridge is running hot.
do you mean that your fridge is not cooling and freezer just freezes up ?
2answers
Frigidaire Refrigerator is warm on top of the frig and freezer but fine on bottom.
Remove the rear lower panel on the unit check to see if the compressor is hot or if its running, should feel the vibration, also listen for any clicking noises.
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Fridge and freezer portion of side-by-side GE Profile TPX21PR not cooling sufficiently. Technician came out and saw that only about 1/3rd of coils on freezer portion had frost and determined that we...
run the diagnostics on the unit from the enclosed tech spec sheet to see if possibly you have a bad thermistor/sensor in the unit,or possibly a bad defrost thermostat or defrost heater or the mainboard in the back is defective
Hi my botton frezer no working the compressor its hot
Compressors are normally 100-120 degrees when being cooled by a condenser fan motor. If there is no fan motor near the compressor then it can run up to 180 degrees, so the compressor temp by itself doesnt mean much. You can take an ampmeter and clamp it around one of the wires to the compressor to see if it is running, drawing anywhere from 1-2.5 amps or trying to start, in which case it may draw up to 20 amps every 3-5 minutes.
Fridge just wont turn on any more. first it leaked water, then it got worse after that. THE FRIDGE SIDE STOPPED COOLING AND THEN THE FREEZER SIDE WENT OUT AS WELL. I CHECKED THE COILS AND DEFROSTED THEM...
try and replace the overload relay and start ptc on the compressor. if the compressor starts then you need to check the current draw on the compressor with a clamp meter if you have one.the current draw should be between 1.2 to 1.6 amps.if it is not within that range then replace the compressor
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
1helpful
Refrigerator is getting no power
Check the relay and the compressor with a volt meter. Make sure that you are getting proper voltage. 110 - 120 volts at both the relay and the compressor. If nothing happens or everytime you try to test and the circuit keeps popping first check for bad wiring make sure nothing has come loose. If all the wiring checks out including the ground then the only thing that will pop a circuitbreaker is a bad compressor meaning it is drawing to many amp and you will either need to have a company replace the compressor for around 600 dollars or get a new unit
1helpful
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
1helpful
Power draw on start up
When the compressor first starts up it can draw as high as 15 amps but for no more then a second or two. After that it should run at 1-1.5 amp and will draw less as it continues to run. After 10 minutes it should pull anywhere from .5-1 amps.
Top Refrigerators Experts
vince
Johnny 1000
