Hamilton Beach Water Cooler with Storage Cabinet Logo
Posted on Nov 07, 2010
My water cooler won't cool water. The hot is piping hot and the cold is very warm. what should i do?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 16, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5241
Points
Check to see if fans are working i just bought a used one and one of the fans was not working and i fixed it and sems to be working
  • Reid Procyshyn
    Reid Procyshyn Oct 15, 2015
    Check fans? How is that helpful? How to check? What to do? What did YOU do?
  • Andrea Ordodi Feb 01, 2016
    How I'd like info too
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 16, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
11791
Points
12
Is this model 87307? I am looking to buy this dispenser 87307. Pls e-mail me at [email protected] Thanks
1helpful
Kenmore Washer 600 Series SM9711916
Wrong water line. Go a head swap the water line. You should be good to go.
Good luck
Mai
What is the temperture range hot/cold
This machine is energy compliant to an extreme. The installation says to have the water heater set to 120 and when you put the machine on HOT it will be cooler than that because it mixes the hot with some cold. WARM is a little more cold and COOL is mostly cold and some warm, COLD is just plain cold.
1helpful
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
2answers
Hi, I have a '99 Jetta, new body shape, 2.0L 4cyl that only blows warm air now and again. It's usually cold but can go warm for a bit then goes cold again. When it's cold the hoses show the warm water is...
Under the hood on top of the firewall you will see two hoses,check both of these are hot(the cooler one is the matrix return pipe)if return pipe is cold then undo the clip and vent off any trapped air.this must be done when the engine is HOT,so take care.........
Cooler not running
Check power to relay. If yes, check compressor is working. If yes, keep your hand on discharge pipe. If it's not warm, cooler is under gas leak. Rectify leak and recharge gas.Thanks.
2answers
I have a 1992 toyota camry le with a 3.0 v6. I'm having an issue with the heating system. It blows somewhat of warm air and not hot air? The engine warms up to normal operating temp. Do i need to change...
I would start by checking the hoses at the heater core. One should be hot the other cooler but still pretty warm. If one is hot and 1 is a lot cooler you probably have a plugged heater core. You can also check to see if you hear the blend door slamming and check air temp change when you switch from full cold to full hot. If there isn't a clunk at full hot or cold the door might be stuck.
1helpful
My BMW 318i has had a new expansion tank fitted after overheating and splitting.After bleeding the cooling system it seems as though the bottom hose is not getting hot any suggestions would be welcome
NORMALY THE HOT FLOW ENTERS THE TOP HOSE AND COOLER WATER LEAVE THE BOTTOM HOSE BACK TO THE BLOCK, SO IF THE TOP HOSE GETS WARM THEN THE RAD IS BLOCKED , IF NIETHER GETS WARM/HOT THEN THERMOSTAT NOT WORKING, OR YOU HAVE BLOCKAGE ELSE WHERE, SO REMOVE BOTH HOSES FLUSH RAD WITH HOSE PIPE, (WHEN ENGINE IS COLD) SEE IF WATER FLOWS OUT AT SAME SPEED AS U R FILLING IT, IF NOT ITS BLOCKED, 2ND REMOVE THERMOSTAT AND FLUSH ENGINE OUT, U CAN BUY RAD FLUSH/CLEANER AND TRY THAT,
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
1helpful
Cool water comes out on warm water setting.
The water that is coming from the hot water pipes is likely not hot because it cooled down while sitting in the pipes. We had similar issues with hot water not being ready when our appliance needed it. We heard about Redytemp from our plumber. We have yet to have anymore problems with having hot water when needed.
3helpful
3answers
Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 • Home
Top Hamilton Beach Water Filters & Coolers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
