Tip & How-To about Clothing Accessories
Tip on how to clean sunglasses
Normal glass or plastic lenses, a quick dunk in warm water usually is enough. Or you can add a couple of drops of dishwashing detergent to get the tough grease. If warm water isn't readily available, a quick spray with a commercial window cleaner also can be used. But be careful if you have an anti-reflection coating on your lenses which is common on glasses that have been prescribed for night driving. These coated surfaces have been specially treated and certain liquids or detergents will often make matters worse by creating smudges on the lens. In these cases you should use an optical spray. The optical spray doesn't have to be specifically designed for sunglasses as any optical spray will work just fine including those designed for cameras..
The surface of the nose pads are generally quite resistant to dirt and natural facial oils as they are usually made from a resistant type of plastic or acetate. However dirt can easily get wedged between the nose pads and their frame mounts. If this should happen just soak them for a couple of hours in warm water to loosen the residue. Then it's a simple task to gently brush away the unwanted dirt with an old soft bristle brush or old toothbrush.
Plastic frames, on the other hand, can form a greenish hue over time due to acidic reactions with the skin's natural oils. It is best to avoid the frame touching the face at all. If you properly adjust the nose pads inward to raise the glasses away from your face you can avoid this calamity. Once the frame has been damaged from the facial oils, it is almost impossible to remove the green coloration. Be sure to routinely tighten the screws of the frame.
By routinely inspecting your glasses and doing preventive maintenance, including regular rinsings in warm water with gentle drying, you can prevent dirt build up in the first place. Then you can enjoy your sunglasses more many years of service.
Clothing Accessories Logo
Rinse solution on Fisher&Paykel dish washer not being used
Problem Possible Cause What to do Dishwasher will not start. No power. Ensure the dishwasher is plugged in and the power supply is turned on at the wall. The door is not properly closed. Close the door. Start/Pause button has not been pressed. Press the Start/Pause button . Water tap not turned on. Ensure water is connected and turned on. Blocked strainer in water inlet hose. Check the strainer and clean if necessary-it is located where the water inlet hose screws into the tap. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Lower spray arm rotates with difficulty. Spray arm holes are blocked by small items or food particles. Clean the spray arm. See 'Care and cleaning' for instructions. Cover of detergent dispenser cannot be closed. Detergent compartment has been overfilled. Remove detergent until the cover can be closed. Detergent dispenser is clogged with remnants of detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Remnants of detergent stuck inside dispenser. Compartment was damp when filled with detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Buttons beep and do not respond. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Water remains inside dishwasher after wash has ended. Drain hose is crimped, bent, or blocked. Check the drain hose and straighten if needed. Pump is jammed. Call your Fisher & Paykel Authorised Service Centre or Customer Care. Filter(s) blocked. Clean the filter(s). See 'Care and cleaning' for instructions. Foaming. Incorrect amount or type of detergent used. See section 'Adding detergent' or consult the detergent manufacturer's instructions. Too much egg in the wash load. Increase the amount of detergent. Rinse aid dosage level too high. Decrease the rinse aid dosage. Rinse aid spills not wiped up. Ensure that all rinse aid spills are wiped up when they occur. Water tap not turned on. Ensure water is connected and turned on. The dishwasher stops suddenly during the wash. Power or water supply has been interrupted. Check the power and water supplies. Knocking or rattling sound during wash. Spray arm knocking against dishes. Pause the wash and rearrange dishes. See sections 'CH and CHP models - Controls and starting a wash' or 'CK models - Controls and starting a wash', and 'Loading'. Dishes have been stacked incorrectly. Unclean dishes. Wash programme unsuitable for load. See section 'Wash programmes and detergent quantities' and select a suitable programme. Soils were too heavily baked on. Dishes may need soaking. Spray arm(s) unable to rotate. Ensure no items are obstructing the spray arm path. Dishwasher overloaded or incorrectly loaded. See the 'Loading' section. The filters are incorrectly inserted. See section 'Care and cleaning'. Detergent put in the wrong compartment. See sections 'Wash programmes and detergent quantities' and 'Adding detergent'. Excessive food not removed from dishes before loading. Scrape all food scraps off dishes before loading. Unsuitable detergent. Only use powdered or tablet detergent designed for domestic dishwashers. Not enough detergent. See 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load and the hardness of your water supply. Spray arm holes are blocked. Clean the spray arm(s). See 'Care and cleaning' for instructions. The filters are blocked. Clean the filters. See 'Care and cleaning' for instructions. Plastic items are discoloured (e.g. stain left by tomato sauce). Not enough detergent, not pre-rinsed. Pre-rinse plastic dishes before placing in the dishwasher and/or add more detergent. Alternatively, using the Rinse programme after adding dishes may minimise staining. Display flashing while Keylock is on. This is normal. The display remains on although the buttons are disabled. No action required. White stains are left on dishes; glasses have a milky appearance. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit the hardness of your water supply. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Dishes, cutlery have not dried. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Items removed too soon. After the end of the wash programme, leave the door ajar and wait for several minutes to help drying. Rinse aid dispenser empty. (The rinse aid indicators are lit.) Add rinse aid. See section 'Using rinse aid' for instructions. Glasses have dull appearance. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Tea stains or traces of lipstick have not been completely removed. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load. Wash temperature too low. Select a wash programme with a higher temperature (see section 'Wash programme data' for information). Traces of rust on cutlery. Cutlery is not sufficiently rustproof. Wash by hand. Glasses clouded and discoloured; milky coating Hard water situation. Increase detergent quantities. Glasses are not dishwasher proof. Wash by hand. Water marks left on glasses and cutlery. Rinse aid level or dosage setting is too low. Ensure there is rinse aid in dispenser. If necessary, increase the rinse aid setting or try using a wash programme with a higher temperature. See sections 'Using rinse aid' and 'Wash programme data'.
Nov 12, 2018 • Dishwashers
How do I stop baumatic dishwasher leaving a sticky residue on glasses and other articles on the top shelf?
Make your dishwasher more effective with these quick tips: 1. Check the sprayer arm. When I opened the dishwasher door during a wash cycle, I learned that some of my utensils are too tall, and they blocked the sprayer arm from rotating. Problem solved! Also look at the holes on the sprayer arm to make sure they are not clogged. Use a toothpick if you need to dislodge anything.
2. Check the drain. Look inside the bottom of the dishwasher and remove any food or objects from the filter. Run the garbage disposal to clear it out before turning on the dishwasher since they share the same drain.
3. Don't overuse detergent. It's a mistake to assume you should always fill up the detergent cup. Check the manual and your detergent. On mine, filling it to the first line (about a third) is enough. Too much detergent can leave residue and etch your glasses.
4. Check your water temperature. If it takes a long time for the hot water to reach your kitchen sink, that means the dishwasher isn't getting enough hot water at the beginning either, and that makes it harder to wash away the food particles and grease. If you need to, turn on the dishwasher after you've used hot water at the kitchen sink.
5. Clean the inside of your dishwasher. Grease, detergent residue, and calcium deposits build up inside your dishwasher. You can use vinegar to wash them away. On a regular basis (every few months or so), run a wash cycle while your dishwasher is empty. Don't use detergent, but turn on the dishwasher and let it run for a few minutes until water starts to fill up the bottom. Then add one or two cups of white vinegar to the water and let it finish the cycle.
Sometimes using a dishwasher is an experiment in finding the right combination for hard or soft water, the detergent, and a rinse aid.
Best of luck
BBBBB
frigidaire d. w. grit and white film on glasses
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes).
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
2answers
Someone put dishsoap in the dishwasher
Hello jennifer, welcome to fixya. I usually find this works... If you have your normal dishwasher detergent such as Cascade, Electrosol etc. add some directly into the tub of the unit as this type of detergent actually has an "anti-sudsing" agent added to it and will neutralize any "soap" introduced to the machine. Don't be shy with the stuff, be generous it will likely require a couple or a few tablespoons full. You may need to repeat the process or just add a ton of dishwasher detergent as well as some vegetable oil which will help neutralize the soap as well. Select a "normal wash" cycle, but monitor it closely. If you notice it sudsing add more detergent and make sure the water is good and hot at your kitchen tap before turning it on.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...that's life ;o) Please take a moment and rate this solution favorably after experiencing positive result's. Let me know either way please. Thank you for visiting "fixya" today.
Good luck.
macmarkus :)
Flash stuck on LG VX6100
If it survived one dunking it will most liklet survive a second SOOOOO. I am into R/C stuff and when our gear gets dunked we rinse it out with ultra pure water, Deionised/distilled water if you can get it. I think that the detergent in the washing machine may have left a residue and be affecting your electronics so if you wash it carefully in distilled water (yep dunk it again, crack it open and wash it all inside)to get rid of the detergent residue on the board (note REMOVE BATTERY). Afterwards dunk it in methylated spirits (test to make sure it wont affect any plastic parts first)to remove the water and leave to dry in a warm spot for a day at least. 2 years ago I dropped a $500 transmitter in a dirty dam (Acid /fuel/road runoff)and did exactly this and its been fine ever since. Worked the next day in fact. Its not a mobile phone but its always worth a chance. Once you've finished you may want to take it apart after you've tested it if its going and spray the board with CRC 226 circuit cleaner and water repeller. I've got it on all of my R/C gear and it gets regularly soaked for up to 1hr at a time in muddy water and is all fine.
Apr 30, 2007 • LG VX6000
Top Clothing Accessories Experts
Don A
Don A
john h
ADMIN Andrew
ADMIN Andrew
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
