Stoves 720EF Electric Double Oven Logo
Posted on Nov 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can i do? i do not have the manufacturers instructions and don't know what model it is, i found it in the house when we bought it. thanks
Anonymous
Level 2:
  • Expert 250 Answers
  • Posted on Nov 18, 2010
Anonymous
Expert
Level 2:
Answers
250
Questions
5
Helped
143527
Points
506
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
No power to the double oven but the hob still works
The double oven will only work if a time is set on the clock. Any time will do, you just have to set a time. The grill/top oven is independent of the clock. If the clock is faulty espare can sorce them for you.
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
2answers
How can I bypass the clock on my Stoves Heritage 720 ef oven?
I think you will find that the clock/timer is an integral part of the oven and so if it is faulty or missing, the oven will not work. Because it controls so many things, I would say it would be easier to buy a new clock.
Faulty programmer - oven switches itself off
Try powering everything off at the main switch, waiting a few mins, switching back on and set the clock. Make sure the oven clock is in manual mode and switch the oven on and see what happens.Let mw know.
Main Oven fan stopped and not getting hot
When you say stopped, is it just the oven fan and the cooling fan is still running? Is the oven control knob still lit and is the main oven LED on?
Is the time set on the clock and is the clock set to manual?
4helpful
Reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
8helpful
2answers
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
4helpful
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
