Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jan 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Duet HT washer stops in the middle of the cycle and flashes a H F error. During all wash cycles the machine will start the cycle. Then at some point during the cycle the machine will stop and a error code HF will flash. It can be turned off and the reset to a rise and spin to drain the machine.
myrlanthian
Level 2:
Sergeant:
  • Expert 250 Answers
  • Posted on Jan 14, 2018
myrlanthian
Expert
Level 2:
Sergeant:
Answers
250
Questions
0
Helped
114707
Points
718
Have you tried running a cold wash? Could be a heating fault. If it runs a cold wash fine then id go with that as a starting point
5 Related Answers
Jimster
James Greene
  • 240 Answers
  • Posted on Sep 09, 2007
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
A
Anonymous
  • Posted on Mar 08, 2008
SOURCE: code dc appears and has trouble draining and spinning during last 12minutes
The code is dc not fl for the flow problem do I have to claen the screens
Anonymous
  • 26 Answers
  • Posted on Dec 20, 2008
SOURCE: whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
fl_hot_cold_back_of_washer.jpg Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTES:
  • On some washers, when the washer is started for the first time after this error code, it will begin to drain. You will not be able to pause or cancel the cycle for about 8 minutes while it drains. This is normal.
  • If the error remains on the display, and all of the other conditions above have been checked, call for service.
Mukesh Kumar
  • 3230 Answers
  • Posted on Mar 28, 2009
SOURCE: Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
scottludwig3
Scott Ludwig
  • 5 Answers
  • Posted on Nov 17, 2009
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
1helpful
Whirlpool Duet HT WFW9200SQ/A: Stopped during wash cycle. No code but display flashed 56, assuming that's the time left. Why did the washer stop?
Maybe power was lost temporarily. Try pressing start / resume button. Or cancel cycle and start over. Also Check drain pump for obstructions.
IT OFTEN (MORE AND MORE LATEY) WILL STOP IN THE MIDDLE OF A WASH CYCLE AND FLASH F 11 AND SOETIMES DL- I CAN'T GET IT TO START AGAIN. IT USE TO HAPPEN ONLY DURING NORMAL WASH CYCLE, BUT MORE RECENTLY, IT...
F11 indicates a problem with the Motherboard that goes into the Computer Control Unit.
Is an expensive part (£150/$200) plus labour so maybe time to just move on......
1helpful
Whirlpool Duet washer, during the wash cycle, get H F error code
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
1helpful
Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Washer won't stop beeping and can not change cycle selections
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
