Question about Homedics PS-200 Iron with Auto Shut-off
Would you return this PS200 steamer?
I just bought a Homedics/Home Touch (commercail) PS200 steamer. It arived yesterday. I put the water in, Then I plugged in the electrcity and waited... and waited. NO lights, and only a smwll to moderate amoout of steam came out of the steam vents.
I tried everythg I can think of. Do you think I shouled return it?
What is/does the grey switch aong the edge, toward the corner do/for?
There were no instructions with it. Any /ALL thoughts and suggestions will be appreciated!
  • Anonymous Dec 04, 2008
    I get about 3 min of steam and then it just stops!  I am so mad!  I cannot get assistance, trouble shooting didn't help, and it is just a terrible product.
  • franmjackson
    franmjackson Jul 29, 2012
    I have the same problem. Does anyone have a solution.
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Posted on Dec 31, 2008
  • Beth Davis Mar 04, 2012
    Not so~ I have had the the hose straight up for a half hour. "On" light is lit--- no steam. Worked 2 separate occasions. No more.
Anonymous
SOURCE:
How do you clean a Home touch PS 250B clothes steamer?
I have a hand steamer and use it every time I wear a garment that's a wrinkle-magnet. Usually it does the trick but I may have to steam it for five to ten minutes. Floor steamers that are often used in department stores have a larger capacity water tank and tend to be the most effective. But they also cost a lot more than a hand-held steamer.
Jan 13, 2017 | Irons
Clothes steamer won't steam home touch
The steam not only removes wrinkles, it freshens the fabrics - making them look cleaner. You can use this steamer on clothing, bedding and table linens and also to remove.
Jun 23, 2014 | Rowenta Commercial Garment Steamer - White
Use Manual Garment Steamer Model PS-300
If you have the Home Pro Professional Garment Steamer PS-300 from Homedics, the Homedics website has the manual on their support page. Go to http://www.homedics.com.ph/instructionbooks/ .
then use the drop down menu to select the PS-300. Click on Download to get the instruction book. Note: the file is a PDF, so you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Jan 20, 2014 | Irons
MANUAL FOR PS 350 HOME TOUCH GARMENT STEAMER
First-time ever used. Water filter installed. WON'T STOP BEEPING AND START STEAMING.
Mar 03, 2012 | Irons
No steam coming out
Is the red overheat warning ligth on? if so, press the reset button, that should reset the thermostat and make it work again.
Mar 13, 2010 | Homedics PS-200 Iron with Auto Shut-off
Need a User Manual
my home touch ps200 has the reset button that wont reset ?
Oct 10, 2009 | Irons
Plugged in, reset button is lit, won't go off
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
Apr 20, 2009 | Homedics PS-200 Iron with Auto Shut-off
Replacement parts for homedics ps-200 steamer
I'm looking for same thing.
Jan 09, 2009 | Irons
Home touch 300 no steam coming out
Hold the hose straight up fully extended for several seconds--it says to do this in the manual--and works great
Nov 15, 2008 | Homedics PS-200 Iron with Auto Shut-off
Homedics PS-200 Iron with Auto Shut-off Logo
2,373 people viewed this question
Top Homedics Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Homedics Iron Expert? Answer questions, earn points and help others
