Other computer aer working only 1 computer is not working. Check the IP address on that computer when connected to the router with the cable. you should get the private IP address. Click Here for more info
In MAC Address binding, you should put the actual MAC Address of the iPod not the IP Address, they are different. Normally the MAC Address of the device can be seen on the sticker at the back of the device. Another way to identify the MAC address is go to Menu/Settings of the device and look for Device/System Information. MAC Adress usually have 12 hexadecimal characters (6 pairs). Now locate the MAC address of your device and enter that in the MAC Address Binding settings. That should work.
With this particular router you will need to treat the port range field as the port field. You will just have to forward single ports at a time. Which will be fine. In case you need more reference see the link below.
The default IP address is 192.168.1.1 The manual is here: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=WL-520gC Have you used the setup CD?
To enable WEP encryption requires configuration changes in two places the router (WL-520G) and for the network adapter on the associated with the computer expecting to use the wireless router. Do you both believe you made the appropriate changes to both devices required? The router and the computer
Another possible issue is either the router or the network adapter do not support WEP meaning the option is not possible at all.
