SOURCE: Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
[email protected]
SOURCE: canon error
We do not work for FixYa.... This a free web site to answer questions you may have FOR FREE. I DO NOT GET PAID FOR THIS INFO........ OK, on the same page????? I have had this problem before, I, also ordered a lamp and the pcb and it did not work as well. I had to take a lamp and pcb from a working copier of the same mode to finally solve the problem. Try that first... It could also be a problem with the CCD unit?
SOURCE: CANON IR 2220 POWER PROBLEM
Does it show error code? Also does it ever get out of the wait state? The "bar" at the bottom? Also, does it ever go in to the regular display sceen? If the display turns black, do you see a code or numbers like "602-001" ? Need some more info then just turns on and then off
SOURCE: Canon IR C3200N scan with MAC OSX
Hi!
Please download the drivers from the Canon Website.
Please rate this solution if you find this solution helpful.
Thanks
Rylee
