One day ,my washing machine stopeed IE as error code due to no water.Then immediately i powered off the machine and immediately switched on ,then my display gives error code as "CL".
here after i am not able to operate my mahine.
Kindly give some solution .thanks in advance.
Regards
Vetri
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Vetri.
Check your water inlets.Try restarting the machine by unplugging it again ,then if this fails you may an overloaded motor.
Your drum motor has a 7 year warranty.
1 877 714 7486 for service.
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
