SOURCE: scattered movement
Try using the mouse over a plain white sheet of paper and see if this helps.
SOURCE: logitech v220 cordless mouse - worked fine for 6
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
SOURCE: My trackball is okay with large, sweeping
Background:
I have a total of six Logitech trackballs; four of the newer Trackman Wheel model, and two of the older Trackman Marble+ model (as pictured). All but one of them suffer from the problem described by dave48. The fifth, for some mysterious reason, never has this problem.
Solution:
The solution I came up with is to light a candle and let melted wax drip onto the red thumb ball. A single drip falling on three random places on the ball usually does the trick. (The wax should dry as soon as it contacts the ball.) I then start moving the ball around to work the wax onto the teflon points. The movement will be VERY rough initially, but will gradually smooth out the more you use it. Sometimes the initial three drips aren't enough and the ball starts getting rough again, so I will melt three more drips of wax onto the ball and work them in as well.
Conclusion:
This really seems to do the trick and for some reason the points don't seem to need cleaning as often either. You do have to be careful not to remove the wax when performing a cleaning, however. But if you do happen to remove some wax all you need to do is melt some additional wax onto the ball and work it in like before.
SOURCE: slow mouse on any surface
Go to the mouse option in the control panel and adjust your mouse speed and sensitivity.
SOURCE: The track ball on my marble mouse doesn't move as
I usually put a bit of really thin oil on the trackball, a tiny tiny amount, linseed oil is good. This tends to help it roll freely.
