SOURCE: No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
SOURCE: broke remote and bought new one
lick on this link and go to contact us . call tech support and they will help you. http://www.bulldogsecurity.com/
SOURCE: Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
SOURCE: Bulldog Deluxe 500, remote not starting the the vehicle
Remove the battery in your remote for 15 sec, then put back in, start your car with your key, wait 15 sec, while the car is running press the * star button 2 times, it should beep , if not try it again, if still nothing post me back and we can go from there
