Make sure that the wall outlet is operational. Try replacing the power cord to the charger to see if that will fix the problem. It is the same power cord used to power most desktop computers. Take the cord with you to an electronics store to ensure you have a good match, they cost less than $20, keep your reciept just in case you need to return it. Plug that in to the charger (if it will fit), turn on the charger's power switch and see if you get any lights on the charger. If not, most likely the charger unit has been damaged and will need to be replaced, $275.00.
