The Maytag Neptune front load has a liquid counter weight that makes it sound as though it is not empty. This is a normal sound, they all sound like that, even mine.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
these tips…
My guess is that something got disturbed in the plug when you pulled it off/put it back on. You turn it to "hot wash" and it does nothing? Does it buzz?
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
check out the hot water tap is on then check out the hot water valve for continuity (poss 27 ohms) then check for blockages in the small inline filter at the valve.
