Actually the matter i like that i have richo aficio photo state machine and now it shows the error code of sc322 how to solve this problem. tell me as soon as possible
sc322 is an error generally caused by a component in the laser unit. However, sometimes a faulty door switch can cause this error as well. The switches in question are the three micro-switches that change state when the right door is opened or closed. They are located on the front right side of the copier, above the fusing unit and behind a plastic cover. If you can remove these switches and test them individually, you can probably find the faulty switch. If not, you can replace all three as a set and hopefully the sc322 error will go away (once you reset the machine).
If replacing the switches do not fix the error, then the problem lies somewhere in the laser unit, possibly with the polygon mirror motor, but your best bet is to replace the whole laser assembly if you can.
there soesnt seem to be an error 890 on system but 880 is mlb you could try and go into the service mode by pressing clear yellow button and then press 107 and hold down the stop button.. thsi lets you into the service screen you want copier sp select 5. mode and go to 5-810 sc reset press execute and turn machine off wait and turn back on it coul djust be a signal error for the address book.. good luck A
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective. BiCU board is defective.
Unfortunately,unit needs service. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
