Bugaboo Frog Stroller Logo
Posted on Oct 23, 2010
The frame is not level. we ordered a new one but we still have the same problem. we now think that it is probably a problem with the chassis but do not know what to do.
Quinny buzz 3
Hi
Yes the 2013 style sub seat can be fitted to a 2005 chassis. Where the sub seat connects into the chassis there will be a plastic clip on either side of the 2013 sub seat that will need to be removed in order for the sub seat to then fit into a 2005 chassis.
I have a 2005 model Quinny Buzz and tried my chassis with a newer model frame. The only difference in seat frame to chassi conection is the format on the tip of the pole that ataches to the chassis. Mine...
Hi
This is not recommended as modification of your Quinny could make the product unsafe to use.
From what you are saying you are trying to use the original 2005 style chassis with a newer model sub seat (seat frame) is this correct?
If so there are rubber bungs on either prong on the sub seat that can be removed in order for this model sub seat to fit in the 2005 chassis. If you'd like more information on doing that please pass on an e-mail address and we can put you in touch with an engineer to discuss.
One side of my Quinny Buzz (2010 model) frame seems to be sinking lower than the other side. With the seat unit on its beginning to look increasingly lopsided. I've never hung shopping on the frame or...
Good Morning
Without inspection we wouldn't be able to advise exactly what has happened to this chassis, but it shouldn't be a case of the chassis warping due to your using it with the handlebar extended, as it has been designed for this use. As the chassis is a 2010 model it is still under warranty: Please contact your retailer with your proof of purchase and ask them to make arrangements for the chassis to come to our engineers for full inspection and any repair work required under the terms and conditions of the 2 year chassis warranty.
3helpful
2answers
I have a bugaboo cameleon 1st generation that has a fault. If i was to buy a new 2nd edition chassis would my carrycot still fix on to this chassis.
I have a second hand chameleon and it feels like the frame is a little loose. Is there any way that you could tighten the frame up?
The chassis of my bugaboo gecko is beyond repair .where can purchase a new chassis??
Bugaboo's can be repaired check my tips section on how to. A new frame is a third of the price of a complete stroller aprox $400 US Go to http://www.bugaboo.com/parts to buy a new frame
3helpful
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
2009 or 2008 quinny buzz model ?
I don't think you're being advised correctly. My Buzz 3 is the 2008 model, which according to Dorel when I contacted them about something else was the first model that included the extra XL seat fabric, and mine has the clip style chassis lock on the side of the frame. The cord style chassis lock is a much older model - perhaps 2006 or 2007, definitely not the newer 2008 or 2009 models. Someone could be selling an older style chassis with the newer coloured fabrics because I think storm might well be a 2009 colour. Mine was originally Charcoal/Black but I have bought new seat fabrics etc and it is now Strawberry red which were both 2008 colours. Hope this helps.
Remove body from chassis
To remove the body from the chassis you need to unbolt the body mount bolts, disconnect all linkages such as throttle, shift, etc., electrical connections and wiring harnesses, brake, fuel and emission lines, heater hoses and AC lines, and lift the body straight up off the frame. You almost have to have access to a car hoist to do this, and to do the job succesfully requires a pretty high level of mechanical aptitude.
Well, that's it ...but if you really have to ask how, you might need to hire some qualified help such as a body and frame repair shop.
1helpful
2answers
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
2answers
Engine
Just about anything is possible but this would be difficult. I think the body/chassis is different. You also have a different transmission between the two bikes; 6 speed on the 650R and 5 speed on the 250R. The 650R is a liquid cooled engine while the 250R is air/oil cooled. They both use different carbs.,
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
