Garden Logo
Anonymous Posted on Oct 22, 2010
RYOBI Model ELT1100QFA. The lower shaft gets hot during use. I believe the lubricated packing is missing on the curved portion. Where might we find a packing material in Sydney, AU?
  • Roy Cagle
    Roy Cagle Oct 23, 2010
    In leiu of some packing material, can you try injecting some lithium base grease into the lower shaft? That is what lubricates the flexible drive shaft and is a scheduled maintenance routine on all trimmers that have flexible drive shafts. If you are able to, then do the upper shaft also by all means.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
401
Points
I have pulled a couple of these apart; they use a blue plastic lubricating blocks to keep the flexible shaft away from the shaft wall.
I found with two different shafts that they disintegrate with a few hours usage. Tried grease but the shaft drive still failed. I tried talking to Ryobi who tell me that there is no separate parts in the assembly (and parts drawing confirms a single part number for the entire shaft assembly. Took them months before they eventually gave me one off the shop floor.
The 1100QFA would be a very good multi-function if they fitted bearings or some other solution.
I have an RYOBI electric line trimmer, model no. ELT1100QFA. I need to install a new 2mm line in the spool but need a diagram for reference. Can you help me with this?
I would recommend taking it to your local Ace Hardware where the know how to do most things. You can always look in the Owner's manual that should be available on the Ryobi web site.
Ryobi cs26
Mike it sounds like the head has sheared where it goes onto the shaft. You may be able to get the head off and see if there is any way of re attaching the shaft but it may be tricky. You could use the modelling clay that is also a resin that sets rock hard. (milliput) works for me.
Oct 18, 2013 • Garden
RYOBI ELT1100 ELECTRIC LINE TRIMMER DRIVE SHAFT PROBLEM
You can find it here
https://www.manualslib.com/manual/640551/Ryobi-Elt1100qfa.html
Hi, I have a RYOBI ELT1100QFA electric line
electric line trimmers suffer from one major design problem
the motor has phosphor bronze bushes and the bottom bush goes dry from the grass juice and wears out and the armature poles out and lacks power to work
to get 5 years is good but it is time to take it in for a service or junk it and get a new one
The lower shaft on my ryobi stoped turning, how do i fix this problem.
You didn't quite give me enough info on which machine you have ... but if it is one that allows the lower half of the shaft to be removed for using other implements, disconnect the shaft and try to turn the inner splined shaft by hand and see if the head turns, if not you may have a broken shaft cable or a frozen bearing in the shaft head...this will necessitate removal of the head and replacement of either the shaft cable or the machine head...if all is working then check the shaft going to the clutch...hope this helps... ;-D
4helpful
Drive shaft not engaging
Hi there Reyles,
On this model, if yo rev the engine and the head just sits there, it can be one of two things.
  1. Clutch not engaging (unlikely)
  2. Broken flex shaft (likely)
You need to partially disassemble the unit to find out. I believe you will need a T25 or T27 torx head. Remove the screws from the clutch housing that connects the engine to the shaft.
Pull it apart. Spin the shaft manually. If nothing its the shaft. Otherwise its the clutch.
Best regards
Mike
1helpful
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
1helpful
3answers
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
