My battery is out on my Jaques Leman diving watch. I wanted to repair it myself. I was told if I took the back off I would break the seal. Im attempting to fix it myself
Thank you for contacting FixYa.
If you have a good quality scuba dive watch that needs to be repaired, such as needing a battery replacement, it can be tempting to do it yourself. After all, don't you just need a screwdriver, a battery and rubber gasket (possibly)?
Well, yes. But if you do it yourself, you run the risk of voiding the warranty.
So if you change it yourself and the watch later floods, you are out of luck. So check your warranty information carefully before you attempt to do anything yourself or have someone other than the manufacturer/authorized dealer do the work.
If the manufacturer changes the batteries or does any other dive watch repair, they will normally retest the watch and certify that it is still water resistant to whatever level applies.
This is not to say that a qualified watch repair shop can't do the job. It's your decision but at least it will be an informed one.
So the long and short of dive watch repair - if it's a good dive watch, you'll probably want the manufacturer/authorized dealer to handle it if you don't want to void the warranty. A cheap dive watch? Probably not worth the bother.
