I don't think that you could program/change the freq of your Motorola GP2000 manually since newer Motorola radios today everything is done by computer and programming sotfware. You need to have software for GP2000, radio interface box ( RIB) and programming cable for GP2000 radio and these devices are not cheap. The best way is to contact a local repair shop to have it done for you or find a two-way radio technician, he could do this if he has all the test equipments required.
Radcom907
Front Panel Programming
Easily programmable functions through its front panel buttons. This feature
allows you the flexibility of customising and re-setting your radio profile while
in the field - without relying on programming equipment such as computers,
cables and power supplies.
Yap programming the frequencies of GP2000 can be done manually thro its front panel buttons.
Yea it is possible to manually program gp2000.Swith on while pressing the Squelch soft button just above the PTT button. A beep will be heard and RW with a square box is displayed at screen.Now press Chanel change button to go your desired channel. now press PTT button the menu goes ahead until you reach TX. Here enter your desired trans frequency by keypad now again press PTT and you will reach RX that is your receive frequency.
If you need to program your GP2000 and replace channel frequencies, text me at 09214841001. RudiePogi
i have my gp 2000, i cant channel it. thnk if solve my problem
all you need on the link above. i fixed all 7 of my Motorola GP2000 model.
thanks..
Http://www.comline.com.sg/motorola/gp2000-programming-instructions.htm
i manually changed my channel the help of the link above. hope it help.
