If it has a 12 volt fan, you can replace it with one designed for computers that has a built-in thermistor. These fans will automatically increase or decrease their RPM depending on the ambient temperature. I have seen them in 70,80,120mm sizes. As long as the inverter is on, you do not want the fan to ever be completely off because even without load some heat is generated and can build up inside if no ventilation is present. Although the fan will never completely turn off, this might be the easiest solution if your goal is to make the inverter quieter (and use less energy) when not in use.
