Question about Kenmore 94812 Top Load Stacked Washer / Dryer
I have a Kenmore 417.94812301 Washer/Dryer combo. During the wash cycle, the tub turns counter-clockwise with the agitator. Everything else works fine. But since it turns during the wash cycle, no downward force is created and the clothes do not cycle up and down through the water. What parts do I need to replace? Thank you
    Top Expert:
  • Kenmore Master
  • 6,289 Answers
Sounds like a transmission or brake problem. Most likely transmission and brake are both in one assembly
Posted on Nov 17, 2017
5 Suggested Answers
6ya staff
SOURCE:
David Coomer
  • 1073 Answers
SOURCE: Kenmore F/L Washer Model 41743142200 tub loose
you may have a dampening shock that is bad
Posted on May 08, 2008
douglas smith
  • 1462 Answers
SOURCE: PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Posted on Sep 07, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 04, 2010
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
tiger56h
hussein mohd
  • 176 Answers
SOURCE: Kenmore Elite Automatic Washer Model #
check the timar
Posted on Aug 23, 2010
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer hums during spin cycle
Either the bearings are frozen, or motor is weakening and has hard turning belt and tub/agitiator
Sep 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Mar 24, 2008 | Bosch WFLI 2440 Front Load Washer
Washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Nov 30, 2006 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
136 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
